Error after upgrading firmware
hello
I installed the k8204 upgrade since today.
but after updating the firmware the x and y carriage stops working, the X stepper motor is stuck but I hear em though, the y motor does not work and I do not hear it
I have placed the X terminal on the z on the motherboard and then it does work, with y the same but does not work on Z.
after i changed the x and y the stepper is stuck
I even tried to change the stepper drivers separately tested in z they al work.
eeprom reset I have already done, but does not help.
I also flashed back the firmware in the meantime but does not help.
does anyone know a solution?
Which arduino version did you use?
1.5.8
That’s the issue!
Use arduino 1.0.6, as the newer version doesn’t copile the firmware correctly. (might be a library issue)
cheers,
Christian
[quote=“ichbinsnur”]That’s the issue!
cheers,
Christian[/quote]
thx Christian problem solved
Nice to hear!
Happy Printing!
cheers,
Christian
