Err: Mintemp - Starts Printing fine but then error
Hi
I am getting a mintemp error.
I have a dual head. It has been printing fine for some months.
When I set temp, the head heats up, printing starts and then the set temp (one on the right) drops to 0 and error is thrown.
I changed the ABS printing temp from 215 to 220. Same problem.
The thermistor reads the temp OK but the set temp bugs out,
I loaded new firmware, problem persists.
HELP!
There must be a bad contact somewhere between the controller board and your thermistor. If the contact is lost event for a tenth of a second the error will be triggered. check the wiring and the plugs and the thermistor itself (broken wire).
Check the screws for the thermistor.
Mine came loose on the heater block and caused a problem.
[quote=“Wrong Way”] screws [/quote]Hey it’s the K8400 not the K8200 there’s no screws holding the thermistor…
The screws for the wire connections for the thermistor on top of the print head (green connectors)
There are 6 on each side 2 for the fan 2 for the thermistor (middle) and 2 for the heating element.
I have the K8200 and the K8400.
