I have made this modification to improve safety and avoid dust exposure from outside on the K8400
thingiverse.com/thing:876709
Closed
Half opened
This rebuild fits well together with Hood enclosure for Velleman K8400
viewtopic.php?f=64&t=13813
Parts were made in Creo 2.
4pc Side Cover (print 2pc for left side and 2pc mirror inverted for right side)
10pc Screw M5x16
10pc Nut M5
6pc Clamp (to fix the cables on the inside)
12pc Screw M3x20
1pc Handle piece for vertical window
3pc Screw M3x25
3pc Nut M3
2pc Screw M4x16
2pc Nut M4
Use with Handle from Thingiverse thingiverse.com/thing:36465
Vertical window
175x363x4mm
Upper and Lower Horizontal Window has to be measured for cutting when pieces are assembled as there will be minor deviation from one printer to another. Do not forget to make a hole for the Z-axis. Maybe possible to introduce a bushing as stabilizer too.
