Enclosure for DC-controlled dimmer (K8064)
For my home automation system I’m using a Wago PLC, which controls K8064 kits for light dimming. I’m wondering if there is a enclosure which can be recommended to install these dimmers in an electrical cabinet with standard dove-tail (DIN) rails?
Thanks for the help
Sorry, no dedicated enclosures
I just wanted to add support to the general point that the K8064 is rather an odd size. It does not fit any standard UK box for wall mounting. With great difficulty I have found only one metal box (happens to be from Appleby) that can be buried in a wall and has a flush lid.
I’m trying to create a custom box using standard plexiglass and stand-off studs. This seems to be the easiest solution at the moment.
Thanks for the help so far.
