Electric Direct current motor control using K8055 card
Hi there
i am new to k8055 card and new also to how to program this card by Visual basic
all i Knew about visual basic is making buttons or tables
The problem here is i have a dc motor and using a sensor to sense currents and voltage
so i want to read the current by k8055 and changing the voltage according to the change of the current
i mean that the current is the input and the voltage is the output
i know i have to put the k8055.dll in system32 and also to put the first code in demo program in general declarations.
So how can i read input and output from external system
also how can change output to input.
Plz i need help in 1 days
Thanks :roll:
Moderator: Edited: We are not blind, you don’t need to use a blue 18pt font.
You need to make an interface, (sorry, we can not do this for you) so the AD channel can read the current and voltage and drive a circuit to adjust the motor voltage.
