Hi
1: Will your new EDU10 require the PICKit2 or can you program it from your PC via the USB port on the board ?
2: Will it be compatible with PICKit3 ?
Thanks, Dave
Hi
Thanks, Dave
EDU10 contains a PICKIT2 clone, there is no need for a PICKIT2 or 3 programmer.
The experiment part of the board is compatible with PICKIT3
Thanks for the very fast reply.
Do you know when the board will be available ?
I wish to buy one.
Thanks Dave
Most likely spring 2013.
