I am hope someone can help. I have assemblied a EDU09 kit and was making progress with calibration but some how I have managed to cause the EDU09 sotware on my Windows 7 PC to run in a tiny window (that I can not move) so that only a part of it is visible. I have uninstalled the software and re-installed to no avail. The only thing that works is to set it to run full screen then it takes over the whole screen. What is the trick to putting things right.
You can try following:
Close the EDU09 software.
Delete the file EDU09.ini in the folder: C:\Users<username>\AppData\Local\Velleman\EDU09
Then run the EDU09 software.
Thank you. It did the trick.
I also only set the softwae installer to install to myself as ‘user’.
All is now well, kit works fine.
