Hi all and happy new years,
I just started electronics as hobby.
I bought edu01 and edu09.
That would be great if there is some samples about how to use edu09 on edu01.
Best regards.
Ahmet
As the EDU01 is fed by a battery, there is no danger in experimenting with a EDU09 on it. Try to make some measurements and try to understand what you see on the EDU09. An EDU09 is like a measuring tool for voltage: use it as a volt meter. You’ll find examples enough in every manual of a multimeter. Mostly volt is measured between ground and a measuring point in the circuit where you want to measure the voltage present.
Ty for your kind reply.
But i wonder whether i can measure frequency on edu01 by edu09.
And if yes, how?
Best regards.
To measure frequency, you need to freeze the image and use the markers to isolate a single period and read the frequency.
ty for ur kind reply.
