I purchased and built the EDU09 Educational PC Oscilloscope Kit. It does not work. The EDU09 software reports no hardware response. No new devices appear in the Human Interface Devices list in Windows Device Manager when I plug the EDU09 into a USB socket My PC uses the latest version of Windows 11 (64 Bit).
Is the ‘Power On’ LED LD1 lit when you connect the USB cable?
Thank You for your reply. I found a previous post on the forum with the same problem as I had and was able to fix the problem. My EDU09 now works perfectly.
No problem.
I’m glad you found a solution.
