Karl45
September 19, 2019, 3:41pm
21
Checked again the Connection from IC3 pin 15+16 via the USB cable - measured directly at the PC- end of the USB cable: OK.
Many thanks for your offer to check the board, I mailed it to your Belgian address.
Greetings from Vienna
Ing. Karl Sruc
Auckenthalergasse 38 1210 Wien Austria
tel +43 664 5107625 E-Mail karl.sruc@aon.at
Karl45
October 7, 2019, 9:49am
22
Did you receive my board?
Any findings?
VEL255
October 14, 2019, 4:47pm
23
I got following info from the repair department:
-That has been restored here the first of October. (bad soldering points)
VEL255
October 15, 2019, 11:17am
Karl45:
Could you fix it?
Yes,the soldering points are fixed.
An invoice is sent to you. After your payment the EDU09 will be sent back to you.
Karl45
October 16, 2019, 5:02pm
26
Letter received, payment done - many thanks for the repair!
In order to learn from it, could you please be so kind to provide me with more detail what had been wrong, where? How can I avoid such failures in the future?
VEL255
October 18, 2019, 6:24am
27
I think all suspicious looking solder joints are fixed.
Here are links for some soldering info:
How to Solder: manual soldering
Common Soldering Problems
