I assembled two EDU08 kits. After trying each of them, they do not show any display. Both deliver the test signal on the test pin (measured with a handheld scope).
On the SK1 plug I measure on both kits the following voltages:
top row:1,3,4,5,7 : 3,3 V - the other pins: about 0 V
bottom row: 2,4,5,6,8 : 3,3 V , the others: 0 V
This looks as being the same result I read with another person on the forum with the same problem on his edu08 kit.
Would it be a problem to send the two kits I have together to you in one box?
Greetings,
Franky De Brouwer
