The kit shows no sign of a display.ave checked the best that I can for dry joints, short circuits, polarity and supply but I am at a loss as to what to try next. I am happy to return for checking if you could supply details or could you suggest other things that I could check
Before sending the unit you can test the voltages on SK1 connector on the top board.
(It is connected to the pin header SK7 on the bottom board.)
You can use the input ground lead as GND reference.
The voltages on the pins should be:
Top row from left to right 3.3, 0, 0, 0, 0, 0, 3.3, 0, 0.4
Bottom row 0, 3.3, 0, 0, 0, 0, 0, 3.3, 0
You can return the EDU08 for inspection/repair to your local Velleman dealer or direct to:
Hi thanks for the prompt response. Have done as you instructed, top row agrees except last pin which read 0v
Bottom row all read 0v. Just to make sure that I have got this right I am testing the pins not the sockets and they are orientated at the top of the board.
[quote]Bottom row all read 0v[/quote]This is very strange result.
The first pin of the top row is connected to the second pin of the bottom row on the main board.
So, on both of these pins there should be same voltage 3.3V.
I’m very sorry I mistook your instructions. I was taking the readings from the pins with the top board detached. Reading from the top board is as follows- top row, pins 1,3,4,5,7= 3.3v 2,6,8,9 = 0v
