just a quick question,
If I order the E3d V6 Should i get the 1.75mm or the 3mm?
What is better and why?
And what is better about the E3D V6 than the original extruder?
Lucas
Lucas
If you want to use the stock extruder gear you should better get the 3mm version.
The Stock extruder is made for 3mm filament. (but it can be modified to use 1.75mm as well)
The E3D will give you mor consistent extrusion, higher extrusion temps (for materials that need more heat), less blobbing and stringing and
a wide variety of usable nozzle sizes.
Thank you very much for the info. I think i will order the V6, the original extruder gives me nothing more than trouble.
Lucas
[quote=“Lucas123”]Thank you very much for the info. I think i will order the V6, the original extruder gives me nothing more than trouble.
Lucas[/quote]
You won’t regret it. It’s much, much better then the stock extruder.
Take care of the cooling, the heatsink must be cooled very well.
I mounted a 30 mm fan at 15V.
