hey guys i have just recieved the e3d v5 hotend for my printer. as the original hot end Teflon cartridge got clogged over night and overheated and broke off at the weakest point. (i hear this has happened to a lot of people)
how do i soldier the 40 ohm transistor to the e3d fan. i assume you just cut the red wire of the fan then solder the resistor to each end of the red wire. then connect it into the blue mains socket on the board. this was not clear in the instructions. please help i do not want to damage the board. thank you for your time
