Hi, in the Velleman user guide says about printing with two head you can either use:
one file with several closed non intersecting meshes
combine several STL’s that make perfect fit
I tried the first option, but my CAD program doesn’t generate compatible STL’s for repetier (non manifold, can’t split objects)
About the secind option: How can you import several stl’s into repetier and ‘merge’ them perfectly (tight, non overlapping?
