TLS
                    May 7, 2015,  6:55pm
              1
              Hi, the repetier software refuses to use the second extruder if there are no objects that require the first extruder.
So I can use the second extruder, on condition that there are also objects in first extruder colour.
Practical: I cannot print a single object with the second extruder, even when I select ‘extR2’ in the object three before slicing.
What am I missing or is this a bug?
              Same problem here. I can only use the second extruder when I use both of them. Must be a bug.
                raby
                    May 7, 2015,  8:39pm
              3
              To use the second extruder you must use the “Single head” Print Configuration in the Slicer tab and select EXTR 2 for your object in the Object Placement tab.
                TLS
                    May 7, 2015,  8:55pm
              4
              Here’s the solution, it works:
viewtopic.php?f=61&t=14620
edit: indeed, Raby’s solution; thanx Raby
