I just received a PCS500 scope with a parallel port connection . I’ve upgraded the software to the latest version - 4.05. PC is running WinXP and LPT1 is set via BIOS to normal, although I’ve also set it for ECP and Bidirectional with the same results for the following problem:
When I boot the PC, the red power light on the front of the unit goes on and the scope operates normally. If I shut down the software for the scope, the red light goes out. If I then restart the software, the red light does not come on and I repeatedly get a message that there was a load error and the DriverLINX could not be found. I’m then instructed to run INSTALL_DRV.EXE to install the driver. I do this and everything works fine after rebooting, but as soon as I shut down the program and then try to run it again, the same thing happens. Is this normal behavior for the program or is there something I’m missing. Thanks.
