I developed a sophisticated control program for the PCGU1000. I use “Setup factory 9” to distribute my program to my customers.
But for the first time of use I also need to include the drivers of the PCGU1000 V5.4.0.0.
My problem is that the installation procedure via the device manager is absolute not user friendly. It gives a lot of problems because not all my customers do have knowledge of drivers installations.
Do you have a more convenient procedure e.g. by starting up executable file that does the driver installation?
This file could than be included in the setup procedure of “Setup Factory 9”
Here a link to download the PCGU1000 driver with an installation executable: box.net/shared/4s5rpv8or6
To install the driver extract the files to a folder and then run the [color=#800000]PCGU1000DriverInstaller.exe[/color] in the folder.
The installation executable is used to copy driver files and register a device on a PC before the PCGU1000 device has been connected.
When the device is connected to the PC for the first time, the drivers will be installed with little interaction from the user. (E.g. In Windows XP the user should select “Install the software automatically”.)
Please check also the workaround to use the PCGU1000 on 64-bit Vista or Windows 7.
You’ll find the instructions in the Release_Notes.pdf included to this PcLab2000SE v4.03 installation package: velleman.eu/downloads/files/ … _v4_03.zip
[quote=“VEL255”]Here a link to download the PCGU1000 driver with an installation executable: box.net/shared/4s5rpv8or6
To install the driver run the [color=#800000]PCGU1000DriverInstaller.exe[/color] in the folder.
You’ll find the instructions in the Release_Notes.pdf included to this PcLab2000SE v4.03 installation package: velleman.eu/downloads/files/ … _v4_03.zip[/quote]
^^^THIS is what separates Velleman from the rest–remarkable support for end users and developers!!!
The driver exe file does work much better, Had a problem where the pcgu1000 refused to update the drivers to work on pclab2000se 4.03 kept saying I had the best driver already installed used the exe file I found out about here and now it works fine thanks for the help!!!
