Trying to install drivers for PCSGU250 on a Windows 8 laptop. The scope shows up in device manager with the yellow icon. I down loaded the Win8 driver
which is a zip file but, I do not know how to install the driver. Could some one please help?
Thanks, Joe
I copied this from a different post (Thanks VEL255)
You can use the instructions written for the Windows 7 driver install.
Here you can download the detailed step-by-step instructions how to install the driver:https://www.box.com/s/vh9olqyx3idhhxn8ujwm
For more details how to disable the driver signature enforcement please see:
http://answers.microsoft.com/en-us/wind%20…%20a83ca6d852
You can also use these step-by-step instructions how to disable the Driver Signature Enforcement to install a driver:
http://www.fotoclubinc.com/Images/PDF/W%20…%20nstall.pdf
Please see this thread how to disable the driver signature enforcement in Windows 8.1:
viewtopic.php?f=3&t=8339
You can use either the driver: “Drivers for Windows Vista and Windows 7. (Can also be used for Windows XP)”
or “Driver for Microsoft Windows 8 Works with 32 and 64 - bits versions.”
from: http://www.velleman.eu/support/download%20…%20u250&type=
In both cases you should extract the package before install.
Thank you, I try your reply and post results.
