Last week i installed the second extruder kit. Installed everything ok.
But the filament was not feeding, i only heard a beeping sound from the stepper motor of the left extruder.
I swapped out the driver boards between the extruders and the problem was moving with it.
I send back the driver board and received another one, but with the same problem !!
Well if the problem travels with the switching of the driver board. It is obviusly the driver board that is the problem and if the Voltage on the driver check is correct i see no other way then you probably have to make a ticket on it to get it replaced unless velleman support have some other ace up their sleeve as an idea.
[quote=“basvaningen”]I just check the voltage of the “defective” board. It says 0,9125V.
So i think that isn’t the problem…[/quote]
I’ve had a defective one whose voltage was correct when idle but dropped dramatically when in use. So it doesn’t necessarily means it’s OK.
And as Marlak said if the problem moves with the stepper driver it must be faulty.
