I’m looking for a kind of double timer where the first timer is a delay timer and starting the 2nd timer when the first timer is reaching “0”. There should also be a relay activation when the 2nd timer is running. It should also be useful that there is an indication of the status of the timers (display?). Any idea if this is realizable by a Velleman kit (K6000?)
K6000 does not allow such operation. For short delays, you can use MK111, for long delays, the K8015 can be used. Both kits do not feature a display.
