Used PCS10/K8947 in DVM display mode and checked readings with a digital voltmeter.
Results with 3 V scale :
CH 1 - PCS10 00,00 V - Voltmeter 0,187 V
CH 2 - PCS10 00,00 V - Voltmeter 0,015 V
CH 3 - PCS10 00,11 V - Voltmeter 0,202 V
CH 4 - PCS10 00,00 V - Voltmeter 0,000 V
Furthermore, calibrated known potential difference of 1 V does not show this difference amount between connected channels.
Thanks. Measurements being false even at 200 mV, which is 6% of 3V scale, does this means the 3V scale is not reliable at all ? I measure datas between 0 and 1V. May I amplify the signals and if yes, with what item ?
[quote]Measurements being false even at 200 mV, which is 6% of 3V scale, does this means the 3V scale is not reliable at all ?[/quote] On all scales you get better accuracy if you use the upper part of the scale.
[quote]May I amplify the signals and if yes, with what item ?[/quote]Yes, if you need high accuracy at very low voltage levels. You may use operational amplifier.
I need to measure values between 0 mV and 1500 mV with a +/- 5 to 10 mV precision. I am not familiar with electronics at all. What kind of op. amplifier must I use and how shall I connect it to the voltmeter ? Is it a single apparatus between signal cable and voltmeter input ? Do I need 4 of them for each channel ?
