Displayed values
I've just bought an HPS140 from Maplin (UK).  I've used it to display a DC voltage, and the display is what I expect with a stable shape.  I've changed the scales, trigger etc to get what I want but I don't understand the value displayed at the bottom right.  If I set Vmin and change the scale the value changes.
eg. on 4V/div I get -14.33V↓ on 10V/div I get -34.41V↓
The value changes as Ypos is moved. What is my Vmin?
Regards, bobinski
Vmin: minimum voltage
If you change the Y-pos, you need to reset the GND reference, in order to get a correct readout.
You can reset the GND reference by setting the input to ‘GND’ until the readout is stable, next you can return to ‘AC’ or ‘DC’ coupling.
Thanks, that does work.
