Dislpay dosnt work?
I finally finished the printer and powered up but the Display wont com on ?!
I tried pushing the reset botton but to no avail !
HELP !
Edit.
The red leds on the stoppers light up, aswell as the green light on the mainboard.
Check if the flat cable is inserted far enough and watch the red wire , make sure the red one is correctly positioned on both sides of the flat cable.
Red wire on the flat cable is on the side of the reset button.
on the display its on the left side (front view)
Thx
Ok and check if the pcb and the LCD are connected properly maybe missed a row
Ive been checking that for an hour now, but i just checked it again lol
I have to say that the temp. control wire is not installed yet, i just got a phonecall that they got it now .
And due to the fact that wire is not installed i didnt hook up the heater wire aswell.
Dont think that has anything to do with the display not running but thought i mentioned it anyway.
Thx for the support.
Ron…
Can you take a picture of the LCD connector on top of the SD CARD reader (not the flatcable connector)?
Thank you so much !
Ive found the problem !
As you would have suspected i did not connect the LCD on to the print with the SD card reader !
Stupid mistake i know, thats what you get when you do the assembly to deep in the night !
Thanks again for the support.
Ron…
You’re welcome.
Happy printing!
