I need to replace the pulleys so I’m about to start disassembling the printer. I will also recheck the X/Y linear bearing clamp distances in Step 16 - I didn’t realize the importance of that at the time. I also have the rod calibration tool at the ready.
I have to redo the bottom Z-Rod mounts as I forgot to put the M3 nuts in in Step 5 but only realized in Step 19. I could fix the top ones, but I had to super-glued the bottom ones. I have since printed a ‘tool’ that should allow me to unfasten the M5 bolts holding the mounts to the rear case at the bottom - there’s not much space for a normal allen key unless I remove the controller & power supply…
Does anyone have any tips or warnings?
I will try to post my experience
Wish me luck
