Hi. I bought and assembled the K8028.
Worked fine with one alogen bulb 75Watt but unfortunately the bulb burned out, when replaced I had 6 led flash error.
I cecked the fuse and it was burned out too, replaced the fuse now I have 8 led flashes error.
I think it’s the triac (at least I hope), I’m asking if you assume the same and where I can find a spare one.
Thanks.
Simon.
This is the triac.
TIC225M
You can go to your local Velleman dealer and ask for the component.
Best Regards
VEL337
