Digital output 8, starting light ON
When the card K8055 is supplied, the led “Out8” light On (winkle", and the contact close, then open, then close, then open.
For my industriel solution, i can’t have a motor witch start,then stop,then start, then stop, when i supply the card.
My question is simple (but maybe the solution is hard ^^) :
-How can i stop the winkle of digital outputs number 8 when i begin supply of card.
Thank’s.
[quote]My question is simple (but maybe the solution is hard ^^) :
-How can i stop the winkle of digital outputs number 8 when i begin supply of card.[/quote]
You are right - the solution is very hard: actually impossible.
This feature is hard-coded to the firmware and there is no workaround – sorry.
