As the topic says…Whats the difference between those modules.
Simply couldnt figure it out from the datasheet.
There is no technical difference.
The K8055 is a kit and the VM110 is a pre-assembled module.
so if i order the vm110 it is not necessary to solder the parts onto the board.
this would be necessary when bying the k8085…is that right?
thank you for your fast reply
You are right. No need to do any soldering work if you select the VM110.
