Here is mine. Low quality print @ 0.3mm Z and 60mm/s speed. Can print much higher res but for this model would have taken 12 hours!
I’ve been using my printer for about 5 months now. Really very impressed by how low maintenance it is. A lot of people on the net mess about with tape and mirrors for a flat surface. I don’t do any of this. I print direct to the hot plate without issue. For PLA the bed temp is 50c. You need to give it a good sanding with coarse sandpaper for first use as stated in the instructions. I now just give it a quick wipe with window cleaner between runs to remove any residue. That is the only maintenance I do on the machine.
I’m running it from a Raspberry Pi using Octoprint. I use Cura for slicing and tinkercad for creating my models.
