In an old post, a bug was mentioned in the VM201 initial firmware which caused the VM201 to act as a DHCP server.
This was said to be corrected with the new firmware.
I’m starting to use one VM201 and one VM204. In the network settings, there is an option to enable or disable DHCP. I thought that this meant that the VM card internal DHCP server could be disabled. However, from a support reply I gather that it means that the card will receive a DHCP address from the router or use a static address set in the network settings. Funny thing is that each time that I disable DHCP in the Iphone app settings, it comes back with the enable box ticked. Btw, I have set the router to assign the same address as the one in the app settings.
So what is the situation with the cards working as DHCP servers?
