Hi
My supervisor has purchased VM 110, 8055 USB Experiment interface Board.We have got a CD having Demo version.Can we use this Demo software to measure the analoge and digital values of the sensors.
Hi
Analog sensors having output voltage 0V to 5V or above are possible to use. If the max output voltage is less than 5V the full analog to digital conversion range will not be utilized.
Digital sensors having 0V to minimum 3V logic output (e.g. CMOS, TTL) or having open collector NPN transistor output can be used.
You can use the demo software.
