I have run into an issue with my K8200. When printing the first layer, the PLA’s adherence to the print bed is now quite bad. I get this using both Slic3r’s default start code, as well as Cura’s default start code. For those of you not familiar, Slic3r’s default is to position at 0,0,0 and extrude some amount to prime the nozzle, while Cura’s default is to position at 0,0,15(z) and drag the drip-extruded PLA onto the print bed.
The problem manifests thus: When printing starts, PLA is extruded, but doesn’t adhere right away. Instead, it loops back around to stick to the underside of the nozzle bezel (This is the stock Velleman nozzle, .5 mm). Eventually the extrusion will stick to the print bed, but the nozzle is now dirty and keeps either laying whiskers in addition to the main extrusion, or picks up the previously extruded plastic and ruins the layer.
If I am very diligent in picking off the stuck PLA, and lucky, I can get the skirt to print successfully and things are usually well behaved as long as I’m printing large, simple shapes. However, that’s not what I’m trying to print right now! I’m trying to print out the upgraded Z-axis mount, but when laying the first O-shaped lines for the screw holes, the filament again starts to bind up on the extruder nozzle or nozzle bezel, ruining the layer.
I’ve printed several very similar objects to this (A new fan nozzle and a holder for it). These all have had small round features in the first layer. Really, up until now the printer has been behaving fantastically (Won it in a Christmas raffle, so about 2 months of use). I’ve gone through probably 2 kilos of 3.0 mm PLA.
Here are some more technical details:
This occurs with both the glass plate at 60°C, as well as with painter’s tape at ambient and at 40°C (Yes, I’m cleaning the glass plate with 99% alcohol).
I’m using the latest firmware, but don’t have the upgraded Z-axis installed yet (firmware has been modified to allow this - my Z-axis is calibrated correctly).
Speaking of Z, the bed is level, and the Z-home has been set to achieve perfect positioning when both surfaces are at print temperature.
I get this when printing at both a .25 (.35 first layer) and .20 (.30 first layer) slice.
Temps are always 190°C or 195°C filament, with the print bed either at ambient, 40°C, or 60°C
Filament is MG Chemicals “Gray” 3.0 mm.
Any ideas?
