Recently, I have bought the above mentioned data logger for fermentation experiments. Today I performed the first trail of that and was happy that it worked directly.
With a bubble counter I can measure the bubble produced from yeast cells fermentating sugars.
But in one thing, I was a bit confused. I do not need a sample measure rate of 100 per second. For my purpose it is really enough when the sample rate would be 1 or per second or even 1 per two seconds.
Is there any possibilty, maybe in the software, to change that rate?! I am not a computer specialist but belief in me that I am able to adapt the DLL-file, if necessary. If someone has any instructions for that, how to do, it would be very nice.
Hi!
Thank you for that information. I will test it soon.
Do you know if there is a possibility to further reduce the sample measure rate, maybe to one sample in 2, 3 or 4 seconds.
That would be really slow, but is maybe sufficient for my purpose.
thank you
[quote]Do you know if there is a possibility to further reduce the sample measure rate, maybe to one sample in 2, 3 or 4 seconds.[/quote]Yes, this is possible by increasing the Time/Div setting. The slowest sample rate is one sample in 10 seconds on the 1000 seconds/Div range.
