[size=150]MK3 Aluminium heatbed 240x214cm[/size]
Please note that the Aluminium heatbed can have some marks or minor scratches, but it will only be of cosmetic character and will not affect the use adversely.
Heatbed with 3mm aluminum core. The metallic side is the top print side and the black side is the bottom side.
Dual power supply. Operate at 12 Volt or 24 Volt. (Is possible to run on 15 Volt also on the 12V operation setup.)
There is no mounting holes on this heatbed. However if you need some you have the ability to drill some yourself.
Solder pads for multiple wires (ribbon cable) or a SMD pinhead connector can be mounted. Pads for SMD thermistor 1206 in the center of the plate.
•Dimensions 240mm x 214mm
•Resistance at 12 Volt setting is around 1,5 Ohm
•Resistance at 24 Volt setting is around 2,6 Ohm
@svdv have made a very useful PDF file for “dummies” installing the heatbed. You find it at (v3.0 Download)
If you want to use my frame solution for the heatbed you find the design among my other designs on thingiverse url=http://www.thingiverse.com/Cinya/designs[/url]
size=150 Status Update :
[/size]
If you would want one of the custom sized heatbeds. This is howto :
Price of the bed is : $35
Shipping Sweden : $9
Shipping Internationally : $20
Transfer Payment on Paypal on : teddyhq@hotmail.com (Add complete shipping address in description!!!)
Send me a email with the address also as a reminder and a way for me to send you email if need be for shipping info and support and so on.
PS Make shure you do a transfer and not payment for goods on Paypal or else Paypal will ninja 2,XX with some insurance payment.
size=150 Current Stock Status : 3, Sold : 108[/size]
// Marlark
Eero… The endstops works like a charm stil
Dont know yet what the toll and taxes will be on this. DHL will aparently send me a invoice on that. I havent tested one yet on my own. Will do that tomorrow i hope. in the meanwhile here is a photo of the plate.
