I print a cube 20x20x20,
good news, the cube is not to bad but the measures are not correct,
I have
x=19.54
y=19.93
z=20.16
is it good or not ?
if it is not good, can you give me advice plz ?
I chose a speed rate of 68 otherwise after some minutes I have a print problem.
I keeped the default value in cura.
which speed and speed rate do you use ?
the object :
thingiverse.com/thing:56671/#comments
Pascal
Hi Pascal,
did you calibrate the stepper movements.
Meaning did you adjust the steps per millimeter for the x, y, and z axes
If not, search for “calibration 3d printer” in google.
You will find a lot of information about tit.
Worth reading it.
Best
Frank
hoh61
March 5, 2016, 11:47am
3
my tip:
print another cube with different dimensions: e.g. 30mmx30mmx30mm
Then check the deviations again.
if the deviation is similar (constant offset), you may check your slicer settings,
if the deviation is scaling (linearly increasing), you need to calibrate your stepper movements.
hi,
fran=k, hoh61 thanks for you answers,
I test a cube 40x40x40
cube cube
20 40
x= 19.54 39.75
y= 19.93 39.96
z= 20.16 40.30
so the Z seems linear, Y seems constant, X strange
In more I print a circle, it is not nice, with a second circle I have the same issue.
I suppose a axis is/are not parallel, what do you think.
the problem of my cube, is it the same problem ?
I used the tool http://www.thingiverse.com/thing:606083 for axis.
If i use the calliper for x axis I have 1 mm of difference on X axis.
remake the parallelism, now I have 0.1 of difference, is it good ?
I can’t test now, because my vertex is in a room where night it is cold (19°) without bed, impossible to print
I will test tomorrow
