I got a problem with my interfaceboard K8061. When i want to connect my interfaceboard to my computer there’s a message : “CPU fail”
I have replaced all my IC’s for checking that it wasn’t an IC, but it showed still the “CPU fail”. I also checked the soldering and that seems to be fine…
I’ll hope someone can help me…
grtz
Please check the soldering of IC2.
Also check all the components attached to IC2 (right value, good soldering).
Check the traces going from IC2 to IC3 and IC6.
If all OK, then as a final test you may check if IC2 is defective.
Remove IC2 and replace it with the optocoupler placed now to IC1 socket.
When running the demo program LED LD11 should flash and LD12 should be continuously lit.
The card can’t connect to the pc anymore.
When i put the power cable on the card LD12 is flashing
when i connect the card with the computer LD10 goes on.
