as the sample on the manual pages did not work for me.
On the web-page the plus character is not visible and the copied code does not even compile.
Printing the result lead in a hang of arduino.
I’ve corrected the code as follows, and verified it working with my mobile:
void getcommand (void) // This is the routine that listens and decodes any IR commands. Decodes commands end up in the global vars.
int space1 = 0;
int space2 = 0;
if (Serial.available()) {
Serial.print('*');
rawcommand = Serial.readString();
if (receivelog){
Serial.println("START " + rawcommand + " END\r\nReceived string length = " + rawcommand.length() + "End character > at index = " + rawcommand.indexOf('>'));
//checking and deleting rubbish data at start of received command
if ((rawcommand.indexOf('<') != 0) && (rawcommand.indexOf('<') != -1))
rawcommand.remove(0, rawcommand.indexOf('<'));
//check if received command is correct
if ((rawcommand.charAt(0) == '<') && (rawcommand.indexOf('>') <= 12) && (rawcommand.indexOf('>') != -1) && (rawcommand.length() > 7))
if (receivelog){
Serial.println("Command is VALID");
//breakdown into chunks
//command
command = rawcommand.substring(1, 3);
//finding the spaces to find the times and speedms
for (int i=0; i <= rawcommand.length(); i++ )
if ((rawcommand.charAt(i) == ' ') && (space1 == 0))
space1 = i;
else if ((rawcommand.charAt(i) == ' ') && (space2 == 0))
space2 = i;
//Setting the command variables and checking if they are indeed a number (toInt()).
//times
times = rawcommand.substring(space1 + 1, space2).toInt();
//speedms
speedms = rawcommand.substring(space2 + 1, rawcommand.indexOf('>')).toInt();
if (receivelog){
Serial.println("decoded commands are:");
Serial.println("command = " + command);
Serial.print("times = ");
Serial.println(times, DEC);
Serial.print("speedms = ");
Serial.println(speedms, DEC);
else
if (receivelog){
Serial.println("Command is NOT valid");
resetserial();
