Cooling isolator guide
Does someone knows if the isolator guide needs to be cooled.
If i print with the fans on the temperature won’t go above 220 degr Celsius. If i turn them off no problem with the temperature, but can the isolator guide handle it??
[quote=“basvaningen”]can the isolator guide handle it??[/quote]No the PEEK tube needs cooling or it will melt.
The fans aren’t an all-or-nothing item. Set them at half-speed or something…
