I’m currently strugling to get a VM129 relay card connected to a K8000.
The K8000 is controlled using C# and that works fine for reading the inputs on the K8000.
Also the LED of the outputs seem to work when +I control a 0/I digital output.
When I connect the 0 and the 1 input of a Relais on the VM129 the relay closes.
So that also works.
I suspect that a I/O output on the K8000 functions like a switch? So no voltage, just open circuit / close the circuit?
But when I combine the to cards like :
The LED on the ouput of the K8000 lights up, but the relais does nothing.
What should be the way to connect both cards?
There should be about 12V between the terminals when not activated and low voltage when activated.
The VM129 is connected there and supplies the 12V via the relay coil.
Yes it is in the correct position.
First 8 ports are in OUT position
Last 8 ports are in IN position --> And I can read the input. I used the K8000 only for the input ports until now.
I noticed that the VM129 has a AC-AC 12V supply.
Is that a problem?
If I would try to measure the Ohm that is over the K8000? Is that something that can be done?
And would this be done in parallel with the supply?
[quote]First 8 ports are in OUT position
Last 8 ports are in IN position[/quote]The output optocouplers are in opposite position. Have you checked the notch?
The AC is no problem. There seems to be +12V DC internally on the VM129.
You can use ohmmeter in diode test mode to check the K8000 output.
The VM129 must be disconnected from the K8000 when you are measuring the ohms.
