Hi friends,
I am using e-sun PLA black material.
205-210 C nozzle temperature is aranged for good print quality.
Let me write down the story step by step:
When I started printing last night I started with 205C everything was Ok until software error. due to error printing has stopped.
Than I removed the printed section and cleared the print bed. And started printing again. (By manuel control I hold the temp at 205C while clearing the bed)
But for this print 205C was not enough and I raised up temp to 210C by manual control. with 210C print quality was better.
However, while printing I realised that I am printing wrong model and I stopped printing with emergancy stop.
Again I had removed the printed section. And started printing again.(By manuel control I hold the temp at 210C while clearing the bed)
But for that case, 210C was not enoguh for good printing and than I again raised it up to 215C. As a result I got my part.
In the past this story was the same for some case.
And also, after printing a part, I couldnt print the new one without raising up the extruder temp.
what do you think about this situation?
regards,
Hi There
I have found that when I stop a print, I have to disconnect in Repetier, reset the printer board, then reconnect in Repetier. If you do this quickly, it only takes a few seconds for the temperatures to come back up.
If I don’t do this, then either the extruder goes in reverse, or it will not extrude properly. Possibly this is to do with the temperature!
See if it works for you.
Cheers
Peter
Last night I have faced with the same problem.
I printend one part. And just 2 minutes after I started new print job.
But the second one has not printed at quality of first one.
I also think that temperature sensing is the main problem.
I will try further prints with disconnetcting and resetting the printer.
I suspect that the original psu from Velleman simply can not hold the power for a long time.
so to protect the psu, drops power.
Second, You really should cool the stepper drivers wityh a large or multiple small fans also for the same reason.
Check psu temp and stepper controllers temp, if hot time to switch of the K8200 or modify it , give the heatbed a seperate temperature controlled 24V PSU 10 amp
so that the original velleman psu 15V 6,6Amp has less to do.
I get really good PLA adhesion to the bed glass at 70C (first layer), but it’s very sensitive to nozzle height. I often have to tweak the height between prints as various parts of the machine heat up and change dimension.
