My old laptop Dell Inspiron 3200 is having just one USB 1.0 port.
Using Gembird USB Hub (based on Genesys Logic GL850A) I managed to load the PCGU1000 following this procedure:
- Starting the laptop without the hub
- Connecting the hub
- Connecting the PCSU1000 and PCGU1000 to the hub. THE POWER ADAPTER OF PCGU1000 IS NOT CONNECTED.
- Starting PCLab, after loading the scope open Function Generator. Getting the message to connect the power adapter.
- Closing PCLab, connecting the power adapter to PCGU1000 and starting PCLab again.
- Voila!
Complicated, but works!
I want to use the forum to make some remarks about PCGU1000:
- The inscription at the front panel is misleading - we do not have 10 Vp-p at 50 ohms load. Loading one of the outputs with 50 ohms halves the amplitude. Loading both outputs with 50 ohms is reducing the amplitude more.
- Connecting the two outputs in parallel (without any decoupling between them) is strange for me.
Now some suggestions:
- Include in the waveform library 10-fold sine, triangle and pulse signals. So you increase 10 times the frequency range of the generator. I tryed and it works fine.
- You may open the possibility to exchange *.lib files between PCGU1000 users through your forum.
- I would prefer the attenuated signal (-40 dB) to be available at output No.2 only, while at output No.1 the signal is not attenuated.
