Connecting K8047 with labVIEW problem
Hi
I have a K8047 Velleman datalogger and we want to connect this with Labview.
This is the labVIEW program we used to read the data. (Found on this forum).
I can find the K8047 in the ‘Meassurement and Automation Explorer’ by using the NI-VISA driver.
After running this block program in labview, Here is no error code shown. But there is no data output on the screen too.
What can be the problem?
Thank you
Did you put all these files to the same folder with the VI file?
K8047d.dll
K8047e.exe
FASTTime32.dl
viewtopic.php?f=10&t=14466
I think it may be better to use the K8047D.DLL directly from the VI instead the VISA driver.
viewtopic.php?f=10&t=5652
viewtopic.php?f=10&t=4785&start=15
