Connect PCGU1000 to Labview
We would like to connect the PCGU1000 to labview. Does somebody already have an plugin or an other solution for this problem. We also like to know if it possible that we can run 6 functiongenerators at the same time. Thank you very much!
Jef and Michael
You can only connect one generator /PC and we do not support labview.
Ok thank you for the fast response.
The fact that we cannot connect 6 functiongenerators, would that be a software problem or a hardware issue? If it is a software program, could we use the FGULink.dll to write a different software that could support labview?
Thank you!
Jef and Michael
There is no possibility to “address” the different generators. All have same VID and PID.
