Having run the software downloaded from your website, I am asked to select a port that the 'scope is connected to. Despite there being a drop down menu, none are listed for selection. I have tried ‘COM1’, etc. but to no avail. Does the software support Windows 8 yet or am I missing a trick?
Um, the 'scope doesn’t show up on my device manager. Where is the driver on the website please? I have downloaded what’s specific to the HPS50; no drivers here.
Thanks for your help so far.
I have followed your advice but I can’t guess which folder in drivers to put these in.
Universal Serial Bus controllers?
Ports (COM and LPT)?
Disk drives?
Imaging Devices?
[quote]I have followed your advice but I can’t guess which folder in drivers to put these in.[/quote]What is “these”? And why are you trying to put it a in drivers folder?
In Device Manager, look for a device with a yellow exclamation mark in front of its name. This is probably the HPS50 if all your other hardware is installed correctly. It should be listed under Ports (COM & LPT).
