Configuration vm201
Good evening,
I bought the board VM201da little but I can not use it at a distance (online).
It can only be iPhone 5S home via the app VM201 with WFI home, from idem pc putting the IP of the VM201 tab on the google link.
I have a pc with xp operating system and a telecom modem.
I set to the telecom modem to the port mapping entry:
Name: VM201 - IP destination (IP VM201) - Port Type: TCP - Internal Port: 9760 - External door 9760 - Status: Active
Name: Iphone - IP destination (IP VM201) - Port Type: UDP - Internal Port: 9760 - External door 9760 - Status: Active
The page - Network configuration I set:
NetBIOS name: VM201
DHCP enabled: v
IP Address: IP of the VM201 board
Gateway: IP address of the modem
Subnet Mask: 255.255.255.0
Primary DNS: IP address of the modem
Secondary DNS: 0.0.0.0
Port: 9760
What makes strange to me is that the Status page - down input status I see 9760 OFF.
I have yet to download the TFTP firmware? however, it is only for window 7? I have XP.
Would you please help me a big courtesy
Thank you
