Configuration PC Generator PCG10
Bonjour,
J’ai une cliente qui a acheté un appareil PCG10 pour une utilisation médical, suite au recommendation de son médecin.
Le médecin lui a donner les réglages suivants à appliquer sur l’appareil :
http://www.redtech.ch/vellmann/index.html
Du fait que je n’ai aucune idée de comment cela fonctionne, je vous remercie de bien vouloir m’expliquer comment appliquer et sauvegarder ces réglaces sur le programme Pc_lab2000se
Your customer may use the Wave Sequence option of the generator’s Tools menu to generate this kind of wave sequences.
There is missing a lot of information from the instructions your customer got:
  • What is the waveform (sine or square)?
  • What is proper voltage level? In the instructions there is only said lowest, middle and highest. Lowest from the generator is 100mVpp and highest is 10Vpp.
    Also there is no instruction how to connect the electrodes.
    Even the highest output signal of the PCG10 is anyhow quite safe. The generator is optically isolated from the PC and galvanically isolated from the mains.
    The use of the generator to healing purposes is anyhow beyond its normal use and all the risks are not known.
