I’ve read in another post, that the signal phase of the second output might be set to 180 degrees in a future version of the SW. Is there a chance, that the phase between the two outputs can be freely configured between 0 and 180 degrees with a future SW version? When? Or is there another way to do that? I need a LFO (1Hz to 100Hz) with two synchronized outputs with variable phase 0-180 degrees, so this is a feature I miss
Regards,
Martin
I think you are referring to this thread: viewtopic.php?f=11&t=4239
There is “invert sync” option discussed. This option may be put to the future release to invert the sync output square wave.
The two signal outputs of the PCGU1000 are wired in parallel. There is no possibility to adjust the phase between these outputs.
Also it is not possible to adjust the sync pulse phase compared to the two signal outputs.
One solution to get phase shift between the signal output and the sync output is to create a library waveform having phase shift. E.g. create a library sine wave and start it from selected phase.
Here an example. The phase shift is 30 degrees.
Here the phase shifted signal and sync pulse on the oscilloscope screen:
That’s bad news, but thank you for the quick and helpful response!
Regards,
Martin
