Compatiable version to Repetier v0.84 (WIN)
I have just started using the K8200. The instruction manual says download Repetier V0.84 however only newer versions are available.
Also which driver is best suited for the K8200 ?
You can download the version that was made for the K8200.
It contains the drivers and ini files.
However I think it only works on Windows 7
Click on the link below to download it
http://www.vellemanusa.com/downloads/files/downloads/setup_repetierhost_k8200_0_95f.zip
All of the downloads for the K8200 can be found in this link
http://www.vellemanusa.com/support/downloads/?code=K8200
Hi thank you for your reply.
using the K8200 can you tell me which is the best driver to download
Firmware K8200 marlin V1 or V2 ?
many thanks
The best is to put the v2 directly
If you bought your printer recently, it already contains V2.
