maxdgdg
December 11, 2013, 8:56pm
1
Je pensais etre au maxi des possibilités de ma k8200 :
impression lente, plein de filaments, qualité médiocre
et je tombe sur ca :
youtube.com/watch?v=LbhfQLpHal0
Certes ce n’est pas une k8200 mais l’équivalent
Alors je m’interroge, que faire pour obtenir pareil ?
Changer de fil et passer au 1.75 ?
Changer de buse pour une de 0.2 mm ?
Merci de vos réactions et conseils
david
VEL417
December 12, 2013, 7:40am
2
This product has nothing to do with the K8200.
Can you link to pictures of objects you have printed with your K8200, maybe we can give you some hints on how to improve printing.
maxdgdg
December 12, 2013, 3:44pm
3
Here is a printing with k8200
youtube.com/watch?v=lZwfDeIO-uM
And the print is perfect !!!
i am very far of this result with mine
VEL417
December 12, 2013, 4:05pm
4
Yes, but can you link to prints you have made with your printer?
maxdgdg
December 12, 2013, 4:36pm
5
Here is some pictures of my print
it is not very good …
raby
December 12, 2013, 5:19pm
6
Some improvements might be achievable I think.
So many threads is certainly something avoidable.
You’ll have to check your printer step by step, hardware and software.
Are you printing with ABS or PLA?
As always just a guess.
But it looks like you are running the extruder to hot.
For PLA I run mine around 190C.
Make sure that the thermistor for the hot end is in the little hole.
If it’s not it will make the heat more then it should and cause stringing like the middle picture.
I hope this helps.
