all,
I have connected the P8055-1 USB control board with a P2633 relay board. I connected output 1-4 of P8055 with relay input 1-4 from the P2633. I connecyed the relay GND to the USB baord GND. Releu board is poweren by P1823 set at 9V.
Problem is that the USB board works OK. The connections to the relay baord also seems to work (LEDs light up on relay board at same time as on USB board. However, the relays do not respond.
Any suggestions to solve this problem?
Thanks,
Jack
